ironworker40
NYC Ironworker
My truck has developed a weird front end problem. It will jerk slightly, suddenly one way or the other. Doesn't do it all the time. It did it once back in November. Then didn't do it for weeks. It has been getting worse. If you turn wheels from stop to stop several times it will go away. All the ball joints are tight no play as well as tie rods.
So yesterday I replaced power steering pump because it was leaking at the tank and I was suspecting a worn pump may be the cause of the problem (Ford manual states for front end wander check flow and psi). Still Does the same thing. So I was going to replace steering box and I disconnected the tie rod at the pitman arm. I discovered that the wheels wont steer by hand, not even with two people trying to turn them. Just my luck that I get a truck with 146,000 miles with what looks to be like factory ball joints, that have zero play in them, which is usually not the case, but are too tight and wont turn. I have never seen that before, usually ball joints get loose and sloppy.
So now I'm going to rebuild front end. I have to decide on what brand parts to use. I am leaning toward Spicer Life series Non greasable u joints. Spicer advertises that they are their best.
So has anyone else used them?
What brand ball joints Tie rods have been the best to use?
Should I replace steering box also? I did adjust it about a half of turn last year to take some play out.
Anyone have the part numbers for u joints, tie rods and ball joints? Thanks
