fields_mj
$1800 to gut the front end of his junker
Hey now, I resemble that comment!!! lol
Pretty sure he's thinking you might have to because the bolt's that hold the make believe center pivot brackets are probably jacked up, and if your motor mounts are shot they won't fit out between the oil pan and the crossmember. There's a LOT more to working on other people's **** than most realize, warranty, insurance and accountability come to mind. $1800 to gut the front end of his junker, re install and fix the rear brakes doesn't seem that bad. Wether the rusted out pickup is worth it...well that's up to the op.
A guy has to make a living, and if he does good work, he deserves good money. Unfortunately there's only one way to find out if he does good work or not. One thing's for sure, there are a lot of shops around that have good shop rates that do lousy work.
Just to make sure I have my info correct, the D50 to D60 swap is a straight bolt on swap correct? No special brackets to be made, holes to drill out, no odd ball block off plates to put in from another engine, no 1 in a million odd ball spindle that I may have to find? I'm basically telling the mechanic to do the swap because it should all bolt up with no problems and I'd like to make sure that I'm not lying through my teeth....
Thanks,
Mark
