ford triton motor to c6?
92F350CC
Ford Man
Las Vegas
Are you putting the triton in an older vehicle, or putting the c6 in a truck that has a triton? I would think it would be easier to upgrade the tranny that's already with the motor and keep the OD than to put a C6 in it. Can't see a C6 swap being all that cost effective, but that's just me.
res0wc18
Everett,Wa
no i would be putting a triton motor in front of a c6 because my 460 is toast. Its going in to an 85
MUDKICKR
NITRO WV 25143
what is your fuel system going to be? carb or fi? and no it will not fit to a big block transmission, only a small block, the 4.6 and the 5.4 have the same bolt pattern as the 221,260,289,300,302,351w,351c
res0wc18
Everett,Wa
what about the triton v10?
i dont know how to make them anything but efi, do you?
MUDKICKR
NITRO WV 25143
have fun with wiring, i know its not that bad when you have the whole trk there but if you dont then look out, anyways the 5.4 computer will give you problems depending on what trans you use, if you dont use the one that its hooked to your engine will not run right, the computer runs peramiters for the trans as well and uses that info to adjust engine peramiters as well, good luck
Hyde
N GO SEEK
Idaho
I am going to disagree, the Mod motors are not the same bolt pattern as a small block.
tractorman86
Buckeye, AZ
have a carbureted manifold built for it and do away with hundreds of hours of wiring and abunch of bs even after its done. dont know if ign will give u brob
sassyrel
iowa
have a carbureted manifold built for it and do away with hundreds of hours of wiring and abunch of bs even after its done. dont know if ign will give u prob
sounds good--only one problem i see---air only goes thru the 4.6, and 5.4 intake. so if its the plastic one--there may be problems--the earlier ones had aluminum---having a manifold built could get spendy--
tractorman86
Buckeye, AZ
jegs actually sells a kit made by edelbrock that takes place of the whole intake just like i was thinking and sells all the electronics with it p/n:350-2839 check it out.;Sweet
Nanohawk
