NMB2
Dunce
the first big modification I plan to make to it, after getting it all going, before the turbo is a ZF5. That should help out a good bit too. I know the C6 in all the gasser's ive ever had sucks ALOT of power.
That turbo set up is just like mine. The only down side is the down pipe, it really needs to be 3".
That's what I'm going to have to do for mine. I have heard a lot of people say that they have used 3" flex pipe to make their down pipes.
im trying to keep this truck cheap. Is that turbo setup on there good? I can just build a new downpipe can I not?
If you couldnt tell by the picture of my crawler, I have my own fab-shop. I have no issue bending/welding together a new downpipe.
So as of right now I guess I will pull that entire turbo setup, can anybody give me a list or pictures or article of some sort of everything I will need to take from it? Build new downpipe and 3" single exhaust all the way back. Swap IP from my 7.3 IDI in, and the ZF-5. With this setup I should have no issues towing my 5-6k trailer/crawler/gear. Correct?
For the factory setup, you need all the obvious parts, turbo, up pipe, crossover pipe, intake horn, filter box, oil line, ect. but if you want to keep the CDR then you need the drivers side valve cover, and rememeber to save the two bolts that hole the pedosile to the intake manifold, they're longer. O and chect the glow plug harness, it might be differn't because they moved the controller to get it away from the turbo. I have one and I like it.
