diezelcrazee
For those interested, last night I switched out the new clutch off my 90 with the old one off my 94. The fit was perfect and I could not see any external difference in shape or dimensions. The fans themselves were a little different, as the 94 fan has larger blades so I swapped the clutches out in the fans, and kept the correct fan on each truck.
The 94 now is running about 10 degrees cooler on the real temp gauge I have, and I can hear the fan working more.
Still curious as to why Motorcraft sees a $150 plus difference between these two clutches.....
