DragRag
I'm sure some of you know about these already, but thought I would enlighten those that maybe don't. On the 2008 and up super dury trucks, they came with factory aluminum diff covers. Well, both there rear ends in theres and ours are sterling, so the diff cover fits our trucks to. I wanted to change my fluid, so I decided to buy a new cover from the stealership. They used to be a lot cheaper, but they are still not priced that bad. I got this one for about $60 out the door here at Tiffany Ford in Hollister. Pop yours off, get longer bolts to work with the new cover, yours will not be long enough, install with silicon only, fill with new synthetic fluid like I did, and go. You don't need synthetic, but I wanted it for cold climates, and slightly better performance under heavy loads. You will see my spare tire hangs a bit low in the pic, the rear is a 35 gallon tank is why. This is on my 1994 f350 crew 4x4.
