f350 cab and chassis Ujoints
Duke57
Florida
Need ujoints again. Have the choice between spicer and moog. Replaced all three on the driveshaft 2 years ago and they're starting to squeak again. My work truck, use every day. 92 F350 cab and chassis, zf5.
Any suggestions. Thanks. Mike
Rdnck84_03
Kansas
In my opinion the quality on moog parts has been terrible for about the last 10 years. I don't know how the quality on Spicer is anymore, they were original equipment and usually lasted a long time.
James
u2slow
bilge rat
PNW
I only buy greasable, and cost is a factor. GMB lately (made in japan), moog otherwise.
Actually greasing regularly is the key, proved that to myself over the last 25 years.
Duke57
Florida
I did buy these moogs, they had a threaded opening for a grease fittings but the threaded opening was too small for a standard grease fitting and they came with this weird fitting. But I agree, regular greasing makes them last longer. I had an idea of pulling off all the caps, washing the yoke clean with safety clean, then tapping the opening and re-threading to the proper thread size and screwing in a standard fitting but was in a hurry. I won't be in a hurry this time. Thanks for the reply.
Duke57
Florida
James
I am leaning on spicer though. I may check out GMB's, never heard of them.
GMB has been around for a long time, remember them back in late 80`s or early 90.
I used Spiced on the 86, think it was last summer I replaced them.
X2 on greasing them for longivity, along with Ball Joints and or King Pins. Especially in the winter time.
ihc1470
Idaho
You may not be able to drill a cross as I believe they are harden. Was it a fitting that had a ball in the end and screw driver slot to screw into the cross? If so those take a needle fitting to grease.
So did you just leave the hole open and not grease them? I wonder why they failed then :idiot:
Sometimes getting them to actually thread in is a challenge, I always try to do it on the bench first before installing u joints. The assembly grease they come with isn't enough to last a long time without getting greased after install.
Duke57
Florida
No, it didn't have a slot, and yes, it takes a needle to grease them. It was hexagonal like a regular grease fitting.
Duke57
Florida
No, I didn't leave the hole open. And yes, I did pack them with Shell grease. The same grease I use in aviation applications. It's called Aeroshell 7.
Duke57
Florida
Thanks Mike. I have Torque King bookmarked from awhile back. They sell differential parts also I believe. Pretty intensive website if I remember. I just got home from work. think I will take a look again at their website.
When I had my driveline built, the driveline shop said that greaseable u joints have to be re-greaaed at regular intervals, whereas the construction of service free u joints prevents loss of the grease that is inside them. Either get a service free one, or get that zerk to thread in.
Duke57
Florida
Well, I don't have a needle grease fitting and as IHC1470 mentioned, that may be a hardened cross, I don't know, I thought they were cast. The problem is they were not greased at regular intervals. The next 3 I buy will have the regular grease fitting and not the smaller one. I was surprised to see that small fitting. Happy Thanksgiving.
rreegg
Puget Sound
While on the topic anyone have grease interval recommendations? Have started to use greaseless u-joints on mine but should probably re-grease what hasn't been replaced
dieselmainiac
