So why not just get a truck that's already built that way? Or at least start with a heavier rig. An F-450 (F-Superduty) would work well, and already have 4 wheel disc brakes and a heavy duty rear axle.
CHP may go off axle and tire ratings, but if you ever get in a wreck I bet the lawyers are going to look up the actual official tow rating. You think that in this day and age, especially in CA they're got going to go after an obvious opening like that? I wouldn't be surprised if your insurance company hangs you out to dry too - intentionally overloading the truck probably voids the policy. Good potential for criminal charges too if you kill someone - negligence at the very least.
Factory tow rating are much inflated too I feel - there's not that much real difference between my 85 and a 2015 truck... yet the tow rating is something like 3 times greater. Sure, more power, but power doesn't help you drive safe or control the trailer, in fact makes it worse, not better. Physics is still the same... yet essentially the same 6000lb of truck can no theoretically control 3 times the trailer? Don't think so.
When's the last time you saw truck brakes fail? I never have. I have had trailer brakes not work numerous times. Any truck newer than about 1970 has a split braking system too so it's fail safe - if one part fail you still have 50% or better of the stopping power and you have a nice big brake warning light to tell you. Trailer brakes are not fail safe and there's only one wire that has to fail or have a bad connection or..... moreover, you may not even know it's failed until you need it.
I will say it again - a safe and smart driver will *not* rely solely on electric trailer brakes for control.
I think you will find that a larger truck will be much more comfortable and pleasant to use for towing that weight too. I have pulled 13-14k behind my pickup several times and recently hauled a similar load behind my class 7 box truck - the difference was amazing. With the pickup it's always stressful not because the rig tows that badly but just because I know how easily things can go wrong with that much weight. With the box truck you couldn't even tell the trailer was there.
Incidentally the id can tow some pretty heavy loads quite decently, at least the setup I have can - I can hold at least 35-40 mph going up 5-6% grades towing 14k. I'd expect 30 mph or so on the steepest parts with 18k, which IMHO isn't bad for that much weight.
