Everyone please watch this
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
After having a visitor who wears purple gloves stop by today to inspect an issue, we got to this situation. Just watch. Proof you can run one without the top cover. Black hose is hooked to an electric lift pump to suck "return" fuel out of pump to keep the mess to a minimum.
https://youtu.be/VgqOTR8xXBI
You sir are brave as hell. I did not know this and am happy to see it now. Please do yourself a favor and cut off a few inches of the return line (the steel one) on top of the injection pump so its easier working on the pump. Mine was cut off when I got my rig so I never knew what they originally looked like... Same with the fuel filter air bleeder. Mine as not there and it usually was hell priming in a new fuel filter with no air bleed vent... Fixed that too...:thumbsup::thumbsup::thumbsup::D
laserjock
Almost there...
This should probably end up in the tech section with some more context if it's available. Be good to have it where it won't get lost.
Dieselcrawler
Staff member
Quakertown Pa
I would not recommend doing this though, just showing it is possible. We had a little oopsie when we first started it, never saw Mel move that quickly before. Things can happen faster than you think, and only way to shut it off is sticking your finger in and pushing the right lever. If Mel wants to indulge more info on it he can. Just stating what I know
laserjock
Almost there...
Well, sticking my finger in a running pump is not on my list of things to try personally. I'll leave that to the professionals.
LOL
david85
Campbell River, B.C.
Its been a while since I took the top cover off mine, but I don't think there are any spinning parts accessible from up there. Only levers and springs for the throttle and governor linkage.
