Do you run a regulator with the fawcett?
Regulator not needed with a
Facet pump, nor with any of them from what I can figure. Supposedly it changed the advance, but I put a pressure regulator and a gauge on the thing and set the timing meter on and checked it unregulated and with it cut back to 4 psi and there was no difference at all, so aparantly, that one falls under old wives tales.
I have had PLENTY of experience with Holley red and blue pumps, I've had more than my fair share of hot rods in the past( and 2 Holey pumps on this truck that folded in short order when I first got the thing) and even when properly pre filtered, those darn things just don't hold up, especially in high heat climates. All of which would not be so bad if you could buy all of the parts to rebuild them on the side of the road, but calls to the manufacturer will yield only answers of " you must send the pump back in to the factory for complete rebuild " Which does you no good on the side of the road, so, that is when I started searching for a higher quality pump and went for a commercial duty pump.
When I went to the Carrier dealer to buy one, the parts guy went back in the parts room and waslost back there for quite a while looking for the thing before he finally found them. He came back apologizing because they had never sold one before because they had never had to replace one because they had never had one fail
Bear in mind, all of the reported failures on those pumps have been with excessivly high mixtures of alternative fuels (WMO/WVO) and/or with extra filters on the suction side which they are not designed for.
When operated as designed, they function flawlessly.
