EASY fuel tank filler
Dave7.3
Diesel ******
South Dakota
I have to say, I am VERY happy with the mild filler mod I did to my truck today. After reading through other articles where an external hose had to be added to the tanks, I went searching for another route that didn't bypass the roll over valve.
Looking at the filler neck with the caps off, I noticed a small slot as big as a nickel in the bottom. Just below where the cap would screw in. I had a hunch that might be the factory vent. Going on that, I used a flathead screwdriver and hammer to widen it. I would say it is about as big as a sharpie marker now.
Went to fuel up and I was very pleased with the results! I was actually able to click the filler on the first mark and not have to hold onto the damn thing. Filled both tanks in under five minutes! No more standing there for a half hour getting funny looks from the station attendant. :hail:hail:hail
Thought I would share this and hopefully others that don't want to wrestle with their tanks or don't mind not using the big rig nozzles could have quick fills too!
Cheers,
Dave
Edit: I can try and get some pics if anyone is interested, just to give some visual idea of what was done.
Saber6
NW Wisconsin
Thanks for the idea! A faster easier fill would be great! Get some pics up if you get a chance..
argve
Resident Fruitcake
Gwynneville, Indiana
Yes I would be interested in pictures as well as filling my ONE and ONLY tank at that moment is gettting to be a pain in the rear tank....
Dave7.3
Diesel ******
South Dakota
Alright, I'll get some pics in the morning for you guys. Now just fair warning, it isn't quite enough of a vent to run the pump nozzle full blast (I tried). But, it is enough to at least get the nozzles at the pump to fill on their own without having to baby the thing.
-Dave
zacky6661
the dalles, or
i work at a full serve station (well i live in oregon so self serve is illegal with the exception of diesel by customer preferance) and all the 91 and up f-series diesels, the rear tank is always giving EVERYONE a problem filling up, and they or i usually wind up standing there babying in the fuel. if this is the for sure issue, ill be sure to pass it along to help people out ;Sweet
ghunt
Morgantown, WV
I love the tank vent mod (I did the full mod on mine), I can use the high-volume truck pumps at a station less than a mile from where i work that do 16 gallons in a minute tops ;Sweet
Although, I have found that I can't put the nozzle all the way in, or it will still click and shut off, and this is true for ANY diesel pump, high volume or not. However if I put it about halfway in I can pretty much "set it and forget it" until it's full.
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
So true - I have found in many cases that if I play with the nozzle (sometimes putting it in upside down) I can fill pretty well with out kicking off the nozle.
HammerDown
Glenolden Pa
I had a look see...maybe I'll give it a try.
My issue seems to be the back-up of foam ;Really
Dave7.3
Diesel ******
South Dakota
Alright, had a chance to get photos after charging the camera batteries -cuss
Since I didn't take any photos before the mod, I used the tank filler off of my Dad's 1996 F250 powerstroke. I think the slot might be a little wider on his, see for yourself:
And here is the modified vent on my 1991 F250:
For once, a hammer and screwdriver actually ARE the answer! ;Sweet
Dave7.3
Diesel ******
South Dakota
The rear tank was always the worst one to fill for me too...but this little mod seemed to keep the foam down enough with the nozzle in just a ways like ghunt described.
Hope it works for ya ;Sweet
-Dave
jorge140
