Can the temp. sender from Autometer be screwed into the test port on the drivers side of the E4OD without blocking anything inside since it's longer than the plug that came out?
Yes.... Thats the most used port.... Now if you have a Mag hytec pan it has a location built into the back of it plus.... It has an additional 2 gallons of capasity. Really kind of amazing isn't it...
