cowman79
So the other day my truck started shifting strange when driving. The shifts were not happening at the speed or RPM that they should. Later that day when returning home I was on the interstate running about 70 mph and and the torque convertor unlocked and the od light started flashing. I babied the truck for the next 5 miles until I got off the interstate. While driving, the trucks od light quit flashing and the torque convertor locked up again. When I got off the interstate the truck started shifting and locking up at low rpms. Any questions as to what could be wrong. I replaced the FIPL with a new ford one last summer when I was having trouble with it shifting. The truck had threw a code for the FIPL or TPS. I have tested the FIPL with a meter and the voltage sweep looks good no spiking up or down just a smooth sweep from 1 volt to 3.8 volts or so. Any suggestions was be great. I have a low mileage transmission sitting in the garage waiting to be put in but I don't want to put it in if there is another problem. I have also installed another TCM and the truck has been acting normally since it was installed about two months ago until three days ago when it started acting up again.
