Dyno'd my truck
93iditurbo
victoria b.c
I put my truck on the dyno at my college today and got 140hp at the wheels, sadly the dyno doesnt measure torque. Considering i have a worn out IP, "G" code injectors and im pushing 35's, i thought that number wasnt bad. Anyone have any ideas what the torque might be with a HP number like that?
Optikalillushun
Coal Region, Pa
Corrected hp numbers using a 40% factor puts u at near stock ratings (stock IDI turbo was 190, urs was like 196). Need rpm for torque.
ocnorb
IDIT
Wasatch Front
Correct me if I'm wrong, but isn't peak hp on these motors at max rpm's?
Torque = HP * 5252 /rpm
ocnorb
IDIT
Wasatch Front
Problem is peak torque on these motors is much lower, so you would need to know the hp at peak torque. (I think its around 15-1600 rpm- not sure) Changes the numbers significantly.
Vinceslamer
