dieselrunner
After on the block heater for 3 hours. Truck starts, then sputters out and dies after a about 15 seconds. Cranks for about 15 seconds then fires and runs rough for about 45 seconds. Runs for a couple minutes, then sputters out and dies again. Cranks for 20 seconds fires, runs rough, and idles fairly well afterwards. Drives well for maybe 15 seconds, then it surges and sputters out and dies.
Replaced return lines and that didnt fix the problem. Thought it might be air in lines.
The conclusion I have arrived at is this. Truck gets enough fuel to idle, but anymore (sustained revs or normal driving load) and it sputters and dies. So this would meen a fuel related problem, correct?. With a new fuel filter and return lines does it sound like a fuel pump?
IP has about 40K on it.
So are there tests that can be run to determine a bad fuel pump? Anyone else have ideas what it might be?
Thanks all.
Thanks all.
