fields_mj
I have some possible drive shaft issues, and I'm curious on what others think.
I replaced my U joints about a month ago. Truck has 255K on the clock. I had replace one of them early on at about 175K, so this time I did all 3. Pulled the entire drive shaft out. The old U joints came out without much problem, but the new ones went in REALLY easy. Some of them I could push in by hand. The repair was unplanned, and I had planned on heading out that evening with the camper (5K lbs). Instead, I made the repair, and headed out the next day (2 hrs each way). Everything seemed good. I've noticed a bit of a whine over the last few weeks. My guess is that it's coming from the U joints because of the loose fit. Took the camper out again this past weekend. 45 min trip each way. Drivetrain was making a LOT more noise. Any time I was going down a slight hill where there was virtually no load on the driveshaft/tranny, it knocked really bad. When heading up through 2nd and 3rd gear, if I leaned into it some, I could feel it growl some. This morning on the way to work, it was still doing the same thing.
Does this sound like a drive shaft problem?
Also, I've read of others removing the drive shaft from the rear of the transmission, and they mark it to make sure it goes back on the same. I noticed on mine that one of the splines was wider than the others. I could have sworn that I noticed a matching gap so I didn't worry about it. Could that be the source of the problems, and if so is it fixable? What are the odds that something in the transmission (ZF5) has been damaged during this process?
Lastly, how hard is it to come by a decent, complete used driveshaft? This is my daily driver, and having it out of commission while a shop rebuilds the current driveshaft would be VERY challenging for the family. I really need one that's ready to go so that I can install it after work. Suggestions?
Thanks,
Mark
Thanks,
Mark
