dodge rims
DBogo
Upstate NY
heres the dodge rims but the wont work
and heres the 16.5's
whats the deal with 16.5s im not too familiar with the problems with them
Mike
Stroker
Cora
I havent ever owned a set of 16.5's but I think you have a smaller selection of tires available.
scrappy
16.5's use a different bead that isn't very good at keeping the tires on the bead,it is very shallow and relies heavily on air pressure to keep the tire on the bead. the beads on the 16.5 is shaped kinda like this:\____, (no bead retention ring)where everything else is more like l___^_(bead retention ring)
PackRat
Buzzard Pilot
Kansas
You will have to enlighten me on which year Ford switched to the 100mm metric 8 pattern. Otherwise, the lug pattern is the same on all 8-bolt wheels. 8 on 6 1/2, clear back into the 50's, I believe. I wasn't aware of the clearance issue on the calipers, but I know the GM wheels have a smaller hub pilot hole.
The only benefit I've ever seen, with 16.5's, is they used to be wider than a comparable 16. That is prety much moot, since there is such a variety of size vs aspect ratios, in the 16's.
Only one person I know, has bought 16.5's recently. He has large tires, on a lifted Chev. He liked the way that they look, with a slightly larger wheel, in the big tires. BUT, it's strictly a driver. He rarely, if ever pulls anything with it. At most, a car trailer, with a hobbystocker onboard.
adrianspeeder
USAF C-17 Avionics
Dover AFB / Harrisburg PA
Ford switched to the metric pattern with the 99 superdutys.
The chevy rims have the same 8 on 6.5, but the hub hole is smaller and wont clear the ford hubs.
Adrianspeeder
Bigal093
