GREASE FIRE
i have an aluminum fuel tank in the bed that i bought used off CL. It had a tank vent fitting on the top and i assumed it worked at first but then realized it did not because there was a lot of pressure in the tank when i removed the fill cap (non-vented type). So i took it off just now and need to rig up something in a hurry that works. I do have some check valves around here.
The problem is that i am feeling a bit "mentally challenged" right now because i can't figure out which direction the check valve should be going.
on the one hand, i know the tank needs something to prevent pressure from building up so that makes me think the arrow on the check valve should be pointing away from the tank.
But, it seems the tank is also subject to vacuum because the lift pump is sucking fuel out of it so there needs to be some air coming in as well - right?
this makes me think i would either need to use two check valves, or else find a vented fuel tank cap with 2" female threads that would screw onto the fill neck of this tank, and the cap would have to be vented ways (rather than a check-valve style vent).
could anyone please set me straight on this? it was a hard day with my truck (i will spare you all the rest of the details!)
thanks,
Paul
thanks,
Paul
