Disc conversion on a 93 DRW
FarmerFrank
Blairsville, Pa
I put a 98 shuttle van dually rear in my 94 srw truck. Had to move the perches and shock mounts in 2" on each side. It's a Dana 70u HD rear. I defiantly need a different proportion valve or something with rear disc. They "work" but aren't grabbing hard enough yet.
cpdenton
Truck needs paint.
Conway AR
I have been thinking about a similar conversion on my 91 F350 with a sterling 10.25. TCM(PN 2670) makes a complete kit for this application. Not cheap,but everything is included. Still on the fence. I know there might be cheaper avenues but it does save me a bit of time having to source the various parts,which for me is worth something.
In looking at all the options, I haven't found this one. What company is TCM? Maybe a link?
I'm going to do some digging and get specs for a set up
Sent from my SAMSUNG-SM-G870A using Tapatalk
the set up I posted, bolts to the axle with 3 bolts, you would only need a 1/2" spacer on either side
cpdenton
Truck needs paint.
Conway AR
Brian, do you have any pictures of the set up is installed on your truck? I want to look at how it is installed then do some measurements between a dual rear wheel and I think I'll rear wheel axle to make sure that is all we need.
cpdenton
Truck needs paint.
Conway AR
So, Brian, your brackets bolt to the original flange the backing plate bolted to. On the hub side or the inside?
Looks like you could add a spacer of the appropriate thickness to make up for the extra width of the drw and go.
I am seriously going to go this route after a few measurement confirmations. Thanks guys!
You have the e brake calipers? How hard is it to hook our cables to those?
your cables will not fit, however speedway sells a set that can be mounted and attached.
I don't have a link, because I havnt used it yet.
e-brake is low priority right now.
but yes they are e-brake calipers.
and yes they bolt inplace of the backing plates, inboard, on the rear.
I would make a plate "X" in width, and grab all 3 holes.
you can even use the bracket supplied for a template
cpdenton
Truck needs paint.
Conway AR
Nice, so we could get some of the width by moving the mount plate outboard of the flange, the make a spacer to take up the rest....
If you need replacement calipers in the future, do you know what they came from?
they are cadi calipers I believe, they have numbers on it, if I ever need a replacement ill take it in as a guide.
remember, the master and proportioning valve need to be addressed.
cpdenton
Truck needs paint.
Conway AR
Last question I have. Promise.
Does your 16 inch wheel clear the caliper diameter wise, or are the calipers mounted inboard of the actual wheel. Wonder if the drw wheels and the offset would clear them.
Btw, research seems to show they are 1976-78 Cadillac eldorado calipers.
rustygold
conway Arkansas
But on drw I thought the rotor bolted to the back of the hub so the caliber will clear the wheel.
good question, ill get a pic when theres light, and im not drunk.... whiskey and maple bacon FTW.
placidoert
