Disc conversion on a 93 DRW
rustygold
conway Arkansas
I really don't want to change my axle out unless I have to. Could u steal everything off of one that has disc brakes?
Sent from my SAMSUNG-SM-G870A using Tapatalk
cpdenton
Truck needs paint.
Conway AR
Brian, did you put this kit on your truck? I seem to remember this. How do you like it?
Did you need a proportions get valve? I have the large bore h-boost master cylinder and it wears my rear shoes quicker than I think it should....
yes I have this kit on a single rear wheel.
I like it so far.
ive towed 7k with it and didn't have an issue.
I have a hydroboost, new Fsuperduty master, and a adjustable proportioning valve.
I set it to where im doing 25 mph on a sand road, and they all lock up at the same time.
all ABS deleted.
8700ish GVW before the rebuild. w/ 6 doors.
I really havnt driven the truck much.
mostly the E350 do to other issues.
cpdenton
Truck needs paint.
Conway AR
Wonder if I could adapt it to a drw application. If I am thinking right, the mount bracket would need to move outward 1/2 inch to make the difference on the srw and drw brake show width.....
rustygold
conway Arkansas
I wound if I can change out hubs on the rear to do that seen a weld one for 700 don't like weld on.
if a 1/2" is indeed the measurement, its completely do-able.
a sterling 10.25, is a sterling 260.350+mm .... right?
I wouldn't worry about it needing welded on.
Offroaders are always cutting and welding axles. Not many problems there.
jwsfarrier
Molalla,OR
I have been thinking about a similar conversion on my 91 F350 with a sterling 10.25. TCM(PN 2670) makes a complete kit for this application. Not cheap,but everything is included. Still on the fence. I know there might be cheaper avenues but it does save me a bit of time having to source the various parts,which for me is worth something.
yup, ive welded on many a caliper brackets as well, along with strong backs, shock mounts, 4 bar mounts...
as long as you don't use JB weld.
but everyone has their own way!
rustygold
conway Arkansas
I have a welder but if I could find something to have it bolt on alot more people would be interested.
rustygold
conway Arkansas
This is an 99 to 03 f350 axle it shows drw and srw listed is 40 for srw dics and 41 for the drw dice hubs
