crash-harris
Breaker! Breaker!
So between the time I pulled the radiator, drained/flushed the entire system, replaced with Fleetcharge and installed my coolant filter and about last September, I had to add a gallon of coolant. Between then and about last month I had to add another gallon, then almost another full gallon this evening.
The kicker? NO LEAKS, but I also haven't had any oil or coolant mixing with each other, nor have I experienced any hydrolock.
Hairline cracks in the cylinder walls that only open when hot maybe? Head gasket weeping into the cylinders when hot but not the oil passages? Anyone ever experience this sort of thing?
