When ordering please enter your vehicle's VIN number, the exact model, your engine size, your model year and 2 or 4 wheel drive. Also specify either 4 or 6 stud converter. In example: 1995 Ford F-150 with 7.3 diesel engine and 2 wheel drive, 4 studs.
Anyone got a F150 with a 7.3 diesel in it?
If you've ever searched for a TC, most all claim to be the best.
If you read Racerx advertisement, the TC is for all "The EAGLE BILLET TORQUE CONVERTER for 1989-1998 E4OD transmissions equipped with Ford 7.3 diesel engines."
So why do they ask for all that info I quoted above, all you would need to tell is if you need a 4 or 6 bolt TC.
Why don't they have different prices, for different years?
I have bought different TC's at a much lower cost and didn't see much if any difference in them. From billet to just the steel case.
My thoughts are, A single disc, furnace brazed and low torque is sufficient unless your gonna drag race or pulling.
A triple disc would be nice if your constantly pulling heavy loads of 10K or over, you might get a small amount of slip which would increase the trans temp a little. You have to remember, most all the heat comes from the TC. If you had a PSD and a scanner, you could measure the slip at different loads.
