dieing problems need help please
Reefdiver72
Sludge Slinger
Lancaster/Ohio
Ok I am having problems with it dieing and not wanting to re fire real quick when i come up to stop and push in on the clutch this seems to be the only time i have this problem not sure if its a sensor for idle or what. Thanks I got to get this fixed.
Reefdiver72
Sludge Slinger
Lancaster/Ohio
Well I figured it out thanks whitmore I found a broken wire going to the pump relay where broken and not tied down very wel so it was swingin when you hit a pump going around the corner it was shutting off the fuel when it lost contact. I also fixed a bunch of other wires that looked pretty bad. Thanks Everyone and Smoke ON
