I figured I would post some more D70 info - I would rather use that axle myself due to the parts interchangeability with the front D60, wider gear ratio choices and MUCH MUCH MUCH cheaper lockers... I also believe the info posted about about the differing offsets is incorrect - thre are very few of those axles around and shouldn't ever be found in an 80's or 90's truck. The D70 has a 10.5" ring gear where the Sterling is 10.25
74 and earlier .500 offset
75-77 mostly .625 offset
78 and newer .625 offset
*70 (.500" pinion offset, used from late 1950's to '71 according to dana) these would likely have the lower spline counts, least desirable
*70-B (.625" offset, '71-82) Probably the most common version. Generally 35 spline, but checking is the only sure way.
*70-U (.625" offset, '82+) There seems to be less of these than the 70-B. Known as the "Teardrop 70" because of it's smooth underside. Shares all bearings with the 60
*70-2U (unknown offset) same pinion and carrier bearings as U, but big wheel bearings.
*70-HD (.625" offset, '68+) These come in big trucks, lots of them out there but many in weird widths.
*70-3HD (.969" offset, '87+) Out of newer trucks, not a lot of low gears available for these ones.
*70-High Pinion (unkown offset, 2000ish+ Kodiak/Top Kick K4500/K5500 fronts) 10 lug high pinion 70, with 1550 joints (a 60 uses 1480) 5.13 gears are the only ones available for these axles.
*70-1SU (.625” offset) Super 70. Little info available, Dana lists only available ratios as 4.10 and 4.56. Teardrop housing and HD tubes and outers.
The D70 HD is lighter, stronger and has more ground clearance than a 14B - which is totally a viable option for a rear axle anyway... Talk about ultra common and strong.
