D60 hub/rotor interchange questions 1993/1996
sweet66monza
post falls, ID
I have a 96 DRW dana 60 and SRW hubs off of a 93. I went to install the 93 SRW hubs onto the 96 axle to make it a SRW axle and the rotors are hitting the caliper brackets. Can I put 96 rotors on the 93 hubs and install them or do I need to come up with a pair of 96 D60 SRW hubs?
Thanks!
I think the 96 rotors are slightly bigger diameter than the 93.
But also the 96 should be bolt retainer, 93 is the slide pin.
sweet66monza
post falls, ID
I know the calipers mount different and the auto parts store said the rotors are different 93/96. I just need to know if the hubs are the same or if I need to find a set of 96 hubs
Oh...
Compare the parts numbers for wheel bearings.
I can't remember if they can be swapped or not.
