Wvdirtroad
Trying to identify where these two connections go- the first is is a vacuum line coming off a 4 way (I believe) on the firewall. The hose was disconnected when I bought the truck and it's causing a lack of vacuum pressure in the system. Anyone know where it goes? The second picture is a plug on the drivers side right in front of the battery. I don't see any apparent place for it to plug into, but it comes out of a harness on the radiator support. Lastly- I pulled my injectors today and some of them had a lot of carbon sandy-ish crud on them. Is the normal for regular truck use assuming they haven't been changed in a long time?
