Could it be a lack of friction modifier?
EMD_DRIVER
Say what?!?!
Beaufort, SC
My 97 seriously hates to start moving, if I'm turning at the same time. It does it turning left or right. More so, when turning right. Best way I can describe it, is that it feels like gears binding up. It has the 4.10LS rear in it and the PO had the rear diff cover replaced at a dealer. He didn't say why they replaced the cover, but I figure it wasn't because it was an ugly color.
The PO always had work done at the dealer and lots of parts still have the Ford part stickers on them. Could the dealer have missed putting friction modifier in the diff?
trackspeeder
Stone crusher.
North Branford. CT
Quite possible. Maybe not enough of the smelly crap was added. To little makes them bind up and chatter. To much makes the LS useless. Add a shot and test drive. But don't add to much.
lotzagoodstuff
Carmel, IN
How much is really involved in pulling the cover and changing it? If there's anything really wrong in there, you might see it when you pull the cover.
Just my .02 worth.
EMD_DRIVER
Say what?!?!
Beaufort, SC
Just my .02 worth.
I don't have a problem doing that, but I could easily miss a problem. I've never worked on a diff before.. :dunno
zpd307
Zumbrota, MN
i wouldnt think the friction modifyer would have anything to do with your problem. it is only there to create slip in the diff when turning. i would think bearings, in the carrier or axles..... :dunno you could pull the cover and see if there are chunks of anything in the oil.
trackspeeder
Stone crusher.
North Branford. CT
Lack of the additive will make the dif bind and chatter.
EMD_DRIVER
Say what?!?!
Beaufort, SC
I put in one bottle of friction modifier and haven't noticed any kind of improvement at all. I'll take the truck to work tomorrow and see if putting another 75 miles on it helps...
If not, I'll go exploring for chunks in the differential lube....
zpd307
Zumbrota, MN
maybe you should pull your axles and check the condition of your axle bearings.
MadScientist
