Correct way to measure splined shaft
RLDSL
Diesel fuel abuser
Arkansas
does anyone know the official correct way to go about measuring a splined shaft?
I'm going to ditch the factory steering column and rig a tilt/telescoping one in out of a freightliner , and am having a heck of a time figuring out exactly what the size of the splined shaft on this thing is so I can match up an adapter double ujoint to hook it up to my borgeson steering shaft. I may just end up grinding it down to a square D but i'd like to use the splines on it if possible
The splines are regular pointed splines common to steering shafts
Thanks---Robert
Robert;
It will have a pitch circle, addendum, dedendum, tooth depth (includes clearance below the base circle) as well as pressure angle, clearance/back-lash etc. It may have teeth with parallel or radial teeth or teeth with involute or other forms or profiles. :D ***
typ4
Newberg,OR
Robert;
That was so helpful LOL
just count the input splines, 3/4x 36 rings a bell for some reason.
