Coolant?
Travis91
Hartford/Dothan,AL
Okay its supposed to get down into the 20s tonight and a month or so ago i had a coolant leak(thermostat housing) and i had been dumping distilled water into the system so i know its out of wack. I need to drain everything and add the proper coolant and distilled water. What i don't know is how to drain the radiator, what the proper coolant is, or how much it will hold total.. Im not in the position to do a total flush i don't want to spend hours on end doing this.. I had the radiator out of the truck earlier this year and had it flushed.
The radiator will have a drain petcock on the lower LH side.
Could also just pull the lower hose.
You should pull at least the LH block drain. It's rear of the oil filter. Takes a ¼" drive.
You need 4 gallons of coolant.
I used fleet charge.
One of the flush t's will help getting the air out.
Sent from my USCC-C6721 using Tapatalk
Ruger_556
Ferndale
Any diesel rated coolant will be fine except for extended life coolants that will eat gaskets etc...
GaryB
