8v-of-fury
BAMF FORD
Where has all the oil gone though? I have added 15 litres and nothing on the dipstick? I dont get it...
If you just have straight water in the engine instead of coolant it will boil much easier than actual coolant. That could be the bubbling that you hear. The knock doesn't sound good, is it smoking at all? It sounds like you may have scored the crank a little bit. It may be time to find someone with some more tools to diagnose and hopefully save the engine if at all possible. You may be looking for another engine soon if you continue and you might need to find one already , I hate to sound negative but when ran without good oil pressure it doesn't take long to ruin a crank.
I was just rereading your post and something sounds off, is there a massive puddle anywhere? I sounds like either something went completely wrong on the oil cooler or you have something else bad wrong. I don't think a bad head gasket would cause you to have to add so much oil when trying to fill it up, it would typically push coolant into the cylinders and some into the crank case. If you have lots of oil in the coolant then I would think the oil cooler is still messed up.
dispstick was never touched.. and wouldn't it leak out of that hole if i had 5 more litres of oil then I supposed to have? I am at a wall here.. I have never had a problem like this..
I don't know what to do..i am sorry i am spazzing out.. but im already in a load of crap for having it at home from my mother, and for wrecking the whole driveway.. and now because it cant leave... I am just not thinking rationally.. i haven't any rational thoughts left..
you say the crosshatch is only good for 2 litres.. so thats still to say that 12 or 13 litres is missing.. there is no way it fit in to an already full cooling system.. even with filling the 2-3 litre overflow.. because thats still to say i crammed 10 litres of oil in to the cooling system! this is just beyond me... there has to be an answer for this behaviour..
How was it you said the gauge works? it doesnt have the ability to read 0 just below 7? how does that work? how will it read high? i dont understand it.. a 7 psi on and off switch explain please? lol so if it drops below 7 it bottoms out? and.... im lost.. this sucks
