Shawn MacAnanny
This is on my truck, the coolant system was maintained when i got it, coolant was good, no stop leak, i tested it at 52% glycol, radiator was clean brass/copper but the cap had a pressure leak around the cap seat so i replaced it with an aluminum one at 193k miles. The water pump on it when i got it looked somewhat new, maybe 20k?, it developed a leak so i replaced it at 194k and resealed the oil cooler at this time, and ended up replacing the water pump again 5k later. So this has had the coolant drained and refilled with new coolant and DI water 3 times since i've owned it. The truck now has 203k miles on it. I've put 10k on it since November. This is how much the filter has caught. I will be changing it ever 5k from now on with oil until i dont see this anymore. I think this filter is 27 micron too, in my line of work on large glycol systems (5,000gal+) we filter down to 1 micron so i may look for other filters to atleast get to 5 micron.
One thing i did notice was the restriction orifice in the filter i never noticed before, i had been sending about 75% of heater core coolant through this fitler with a valve i put in, i now cut it to 25% or so since it's not going to flow much anyway.
