Coffee can throwaway
Matrix37495
The Amish Wolfman
Terre Haute, IN
Yea, his vacuum pump was shot and he had a spare compressor layin around. It actually draws it down pretty quick...
Whats so bad about electric vacuum pumps?
FordGuy100
Silverton, OR
I would just think they cant pull the vacuum nearly as fast as a regular one, so braking could be effected?
93cc7.3
needs turbo power
plainfield IN
well for the time being i still have both but the electric is much faster ..
i currently have a bad booster so it leaks bad when u hold it the mechanical cant keep up and takes about a minuite to build 20 hg vac so that i could pump the brakes a second time but the electric will pull 20 in 4 seconds and will pull 30 in about 30 seconds for now i just have it on a toggle and only use it when im sitting in stop and go traffic i need to get a vac switch which is about 35 bucks then it will be automated and i can ditch the mechanical all together
93cc7.3
needs turbo power
plainfield IN
I know on my Ex... the electric vacuum pump will pull down and shut off in about 30 seconds on a cold start..... but, it only runs the hubs and the HVAC Doors.....
FordGuy100
Silverton, OR
And just the smallest leak will cause significant vaccum problems on those SD's. I dont think he has a SD vacuum pump though by the sounds of it
93cc7.3
needs turbo power
plainfield IN
Wow thats pretty darned good it can draw the vacuum down that fast.
ya what it is, is a thomas air compressor that used to be on a airbag helper kit and i switched the input and out on it so that its drawing air out of my 1 gallon air tank then the rest of the vac system of course .... once i have the switch to control it, it should be fool proof because these compressors can run for about 30 mins before thermal shutdown...
i doubt ill ever be holding the brakes for 30 mins lol thats what the ebrake is for
