Clutch Pedal Assembly
cpdenton
Truck needs paint.
Conway AR
I got my pedal assembly out of an OBS f-150. It's the same pedals. Went to the pick n pull and paid about 25 bucks for them. That way you know it fits and everything will work right. Only took about 30 minutes to grab it also. I don't think that first one would ever work well. Too much fab to make anything like that work.
cpdenton
Truck needs paint.
Conway AR
Take the knee cover off under the steering wheel. Take the steering joint at the end of the steering column loose. I did not take the column down to get the new pedals in. You have to take the brake booster loose and move it away from the firewall. Then they come out after some pulling and tugging. Not too bad of a job.
