So my 7.3 is probably the dirtiest on the plant so I was wondering how and what the collective uses to clean their engine in the truck and any thoughts or opinions would be apreciated
Have had good luck with the cheapo oven cleaners. Spray it on and let it sit for a few hours, coming back and adding as it dries out. Then use a medium pressure to wash it off. Repeat until the really thick stuff is gone. Usually only takes two cycles for even the thickest grunge.
