Gary gave me an idea.so what goes into owning a classic truck anyway? think you got what it takes to fix and maintain one? you better be ready......and probably at least a little crazy.
here is chip trucks repair and maintenance list since the day i bought her.
MAINTENANCE & MODIFICATION RECORDS
@ 47,800 Miles (Autumn of Vehicle Purchased/Before Driven :
CarFax Vehicle History Report Purchased
Results: 100% Clean
Oil Change w/ Filter By Previous Owner
(Oil unknown w/Napa Filter - Performed at Local Garage)
Dual Autocraft Titanium 850 CCA Batteries By Previous Owner
POR-15 Rust Preventive Paint By Previous Owner
Coolant Flush By Previous Owner
Transmission Flush w/Filter Including Torque Converter Drain.NAPA Mercon
(made by Valvoline)
B&M Shift Kit & Cooler Installation
Total Glow Plug System Test/Check/Inspection &
8 New motorcraft Beru Glow Plugs
Front Wheel (outer) U-Joints Replaced &
Repacked Front Wheel Bearings
K&N Air Filter w/ Soup Bowl Removal Mod Installed/Performed
Sound Proofing/Keyless Entry Installed
4 Gabriel Shocks Installed
Set of 4 Uniroyal Liberator A/T's Installed
Left Front Drivers Side Brake Caliper Replaced
left front drivers Side Rubber/Caliper Brake Line Replaced
All Steel Brake Lines Replaced
All Emergency Brake Cables Replaced
New Master Cylinder Installed
Pioneer AM/FM/CD/WMA/MP3 Stereo Receiver w/Remote #DEH-P3800MP &
Bench Seat Swapped From Previous '96 f150 Truck
Dump Bed Installed
Speedometer Recalibrated For Shorter Tires
All Fuel Lines Replaced/Tanks To-From Engine w/ Fuel Injector Install Kit
New Fuel Filter
Fuel Selector Valve Replacement
MR.Gasket #12D Electric Fuel Pump Conversion w/Block Off Lift Pump Plate #5422
New Battery Cables Installed w/ All Contact Points Shined Up W/ Sand Paper
To A Mirror Finnish & Greased
Belt & Tensioner Replaced
Wiper Blades Replaced
1 Plastic Return Line T (broke after new install kit,while installing GP's-carefully
installed-passenger side 2nd from front.)
+State Safety Inspected+
+Commercially Registered+
@ 49,700 Miles:
11 quarts of Motorcraft 15W-40 (made by Connoco Phillips)
Motorcraft Powerstroke Filter #FL-1995 (made by Racor)
New Oil Drain Plug Gasket
Front End Greased
Rear Differential Flush
Valvoline DuraBlend (Synthetic Blend) Gear Oil SAE 80W-90
Harley Davidson F-250 Super Duty Center Console Emblem Added To Interior
@ 50,000 - 52,000 Miles:
Custom Exhaust Installed
Used Front 23 Gallon Poly Fuel Tank Installed
Custom Rear Leafs w/Overloads installed
Dump Body Repair & Final Installation
West Coast Mirrors Installed
DORMAN Part # 722005 Rear of Rear Drivers Side Leaf Spring Hanger Replaced
@ 54,000 - 55,000 Miles:
Tire Rotation (all 4/X-Pattern)
Front Wheel Alignment
Complete New Rear Brakes - Minus Drums. Shoes, Wheel Cylinders, Self Adjusters & Hardware
New Rear Drivers Side Brake Cable
Installed Window Visors
Transfer Case Flush w/ Mobil 1 Synthetic ATF
@ 55,000 - 57,000 Miles:
New Front Brake Rotors
Front Wheel Bearings Repacked
Full 6 Wheel Dually Conversion w/ Stainless Simulators Performed
1 Plastic Return Line T (carefully installed-drivers side 2nd from front)
K&N Air Filter Wash & Oil
B&M Trans Filter Kit Installed
Rear View Camera System Installed
Air Conditioning Clutch Plate Installed (used.first time the a/c
has worked since ownership)
Replaced Screw-On Water Drain Bowl - Factory Used
@ 59,000 - 62,000 Miles:
Triple Pillar Pod & Digital Gauges Installed
Wire Loom & Black Grommets For Dump Bed Lights Installed
Fuel Return Line Sections Between Front & Second Injector &
Between IP and Front Injector/Drivers Side Replaced
Soundproofing Behind Entire Upper Dash Installed
Couple Stick on Mirrors Added to WC's For Increased Visibility
Homemade Cowl Induction Installed
SCA Test.Results; Time To Add A Little
Coolant Flush w/ Fleet Charge & Distilled Water
New Motorcraft E5TZ-8575-C Thermostat
New Upper & Lower Radiator Hoses
New 13 lb Radiator Cap W/ Pressure Relief Lever
Reman Cardone Wiper Motor #40-299 w/ Lifetime Warranty Installed
Soundproofing Added To Entire Inner Cowl
Grote 5" Convex Mirrors Added To West Coasts
Front Pioneer Speakers Installed
@ 62,000 - 68,000 Miles:
11 quarts of Mobil 1 Fully Synthetic Turbo Diesel Truck 5W-40 Oil
Mobil 1 M1-601 Synthetic Fiber Extended Performance Oil Filter
Rear Pioneer Speakers Installed
Fisher Minute Mount Snow Plow Installation
Upgraded Headlights w/Relay Mod-Thanks To Plow Wiring
New Winter Wiper Blades
New VSS Installed
Electric Engine Fan Conversion
Engine Timing checked = 8.5 ATDC.Set to 6 ATDC (advanced 2.5 degrees.)
Sea Level - 3000'/ 38-42 Cetane value.
Duralast/Door Jamb Switch #sw1342 Installed
@ 68,000 - 74,000 Miles:
Upgraded To High Quality Dura-Lift Diesel Electric Puller Fuel Pump
Rear Receiver Hitch Installed
Two New LT225/75/16 Kelly Safari Trex Front Tires
Rear Poly Fuel Tank Installed w/Custom Built Filler Tube Bracket
Moog Upper & Lower Ball Joints
Rear Drive Shaft U-joints
Rear Drivers Shock Mount Welded
Front End Alignment
Rear Brake shoes w/E-brake Levers Adjusted
Power Stop Extreme Performance Semi-Metallic Disc Brake Pads #2645002
State Safety Inspection
Sprayed On Complete POR-15 Under Body Coat (finished up where po left off)
w/Flexcoat (Black)
Top Coat On Upper Dump Body.
AKA-Sides & Stakes
New Motorcraft SW5591 Turn Indicator Switch
New Delphi Injectors installed #BB (original were '93 Stanadyne #E) @69k
Delphi Injector Installation Kit #7135-276 w/Viton O-Rings Purchased Separately @69k
IFS (International Fuel Systems) Rebuilt Fuel Injection Pump (from U-Haul inventory
clear out sale)
installed 5/7/2011 @70k
Engine Timing Set to 6 ATDC Sea Level - 3000'/ 38-42 Cetane value @70k
11 quarts of Mobil 1 Fully Synthetic Turbo Diesel Truck 5W-40 Oil w/ Mobil 1 M1-601
Synthetic Fiber
Extended Oil Filter @70k
SCA Coolant Test = Still Perfect @70k
Coolant Filter Installed
Dee Zee Stainless Steel Nerf Bars Installed
Ready-Rad Copper/Brass Radiator #432194 Installed
Hood To Cowl Seal
@ 74,000 - 80,000 (August 2011) Miles:
Custom Built Front Air Dam Installed
Aluminum Sheets Installed Above Dual Wheels On Dump Body C-Channels For Winter Rust
Prevention
Dump Body Pump Flush And Greased
Upgraded To Variable Speed E-fan Controller
Upgraded To Newer JVC USB CD Stereo #KD-R900 W/ MOS-FET Power Amp & TI/Burr-Brown
24-bit DAC.
This Sucker Plays Clear!
Finally Put My Heat Shrink On Battery Cables & Rear View Cam Cables
Dorman Pass Side Window Lift Motor #742-251
Front & Rear Diff Flush w/ Mobil 1 Synthetic Gear Lube LS 75W-90
Larger Universal Under Hood Light Installed
Sound Proofing EZCool Under Hood & Firewall
Dorman Door Hinge Roller - Drivers Side #38350
Hydroboost Brake Upgrade/PS System Flush W/Magnefine Filter & Hayden Cooler
E-Pump Filter Clean,Coolant Filter Replaced
Upgraded Interior Dome Light to '96+ Model
Installed T-stat For External Trans Cooler & Added An E-Fan
Installed Soundproofing On Firewall
Changed Main Fuel Filter
Replaced Inner Tie Rod Ends w/ Moog
Front End Alighnment
Front Tires Rotated Side To Side
@ 80,000 - 84,000 (October 2011) miles
TPS (FIPL) Replaced (it failed) & Set Within Specs
MLPS Replaced & Updated To Latter Plug (preventitive maintaince)
Headlight Switch & Connector Replaced
Synthetic Fiber Extended Oil Filter @80k
Transmission Flush w/Valvoline Mercon 5 (no internal filter change) Wix 51622 External
Filter Changed
Coolant Tested = Passed @ 81k.
FIA Combination Winter Front & Bug Screen Installed
Replaced Outer Tie Rods w/Moog.(foolish not doing them all at once.now i need to
pay for alignment again.)
Upgraded Overload Springs From 3 To 4 Pack
(not to haul more,just to help retain stance for TTB front axle when hauling.)
Complete Front End Alignment.Required 3/4 degree Camber Bushings.
Two New Kelly Safari ATR 225/75/16 w/Tire Rotation & Balance.
Installed Dual Aux Reverse Lights & Backup Alarm.
@ 84,000 - 85,000 (February 2012) miles
Two Used OEM Front Fenders Installed.
New 94-97 PSD Front Bumper w/ Dual Super Duty Lights.One clear & One Yellow set.
Wire Loom Installed Over OD Cancel Switch Wires In Steering Column (preventive
maintenance.)
Fixed Broken Dash Mount.
Replaced Wiper Arm Pivot Mount
(i burned it up cutting out my hole with the torch for cowl induction back along
lol! oops.)
Replaced Cruise Control Servo w/used '95 OEM.
Adjusted Front Tanks Sending Unit So Gauge Reads Empty A Bit Sooner.
HVAC Bulb Replaced.
Water In Fuel Light Circuit Test.Passed.
Removed A Couple Worthless Pounds Of Unused Factory Exhaust Brackets/Hangers etc.
Adjusted Hydroboost Pushrod For Brake Pedal.180 Degrees Rotation.
Fast Idle Solenoid Plunger Adjusted.
New Narrower Rear View Mirror Installed To Fit Backup Cam LCD Better.
Repaired Fuel Selector Dash Switch Mount.
Two New Autocraft Gold Batteries.
@ 85,000 - 90,000 (March 2012) miles
New BRG/BLK Tu-Tone Paint Job (March 16 2012/85k Miles)
Penray Need Release Coolant Filter #NF2088 (85k miles)
Ford Recall #09S09 (better late than never lol)
Synthetic Fiber Extended Oil Filter (85,500 miles)
Electric Fuel Pump Filter Cleaning
Banks Sidewinder Turbo Installed
Added Another Under Bed Toolbox To Pass Side Behind Wheels
Installed Interior Wood Grain Trim Kit
Greased Front End
Installed Rockford Fosgate Amp
Three New Kelly Safari ATR 225/75/16 w/Tire Rotation & Balance
Dump Bed Hydraulic Flush
Installed Fourth & Final Under Body Tool Box To Drivers Side Rear
@ 90,000 miles - 93,000 (June 2012) miles
Upgraded To Racer X Triple Clutch Billet Converter #X4TC w/XLS Option -
Preventative Maintenance/Efficiency Upgrade.
Stock Unit Was Still Working Great
Trans Pump Mods (To Original '93 Pump) Boost Valve w/ Higher Rated Spring & Another Spring
- Suggested,Sold By & Instruction Sheet All From Racer X
Updated Viton Front Seal
Transmission Flush w/ Internal Filter.Valvoline Mercon 5 ATF
U-Joint Replacement - Both Ends Of Front Drive Shaft (Rear Failed/Front Preventative)
Rebuilt Steering Box By Redhead - Stock Unit Had Too Much Slop/Failed Basically
Power Steering/Hydroboost Flush - Mobil 1 Synthetic ATF
Motorcraft SW5978 Neutral Safety Switch/MLPS (teach me to buy an off brand,least i had it all re-pined
for new one already) Set & Verified w/Meter - New Recent Replacement Failed
Manual Shift Lever Bolts Tightened w/Red Loctite (shame on ford for not using loctite on these)
- Loosened slightly/Preventive Maintenance Mostly
Banks Turbo Air Cleaner Housing Sealed Fully For Pressurized Cowl Intake Duct & Wrapped w/Heat Shield
To Reduce Temps From Engine Bay For Max Efficiency
Heater Core/Air Conditioner Box Re-Insulated - Added more All Around To Help Keep Out Engine Bay Temps
- Stock Stuff Was Falling Apart/Failed
Stock Vacuum Pump Delete w/ Dorman #904-214 (SD truck replacement part) Electric VP for HVAC
w/ 5 Amp Fused 40 Amp Relay Triggered off the FSS
Duralast Belt #1080K6 (snug fit without vacuum pump there,but once on,tensioner isn't bottomed out,
and belt is perfect fit)
Crank pulley Replacement - Used OEM - Original Warped Slightly.Always Was Since Truck Purchase
A/C R12 to R134a Retrofit (good old black death kit lol) BRRRRRR! she's colder
than ever even @ Idle w/e-fans.
It's like overkill now.)
Replaced Both hydraulic Hoses For Dump Bed Ram.Made Up @ Napa. - Blew A line Dumping.
timken SET38 Outer bearing
timken 387A Inner bearing
timken 382A Inner race
Timken 415960 Front Inner Wheel Seal - Too early for replacements but since I was in there again.
Premium Dimpled and Slotted Brake Rotors Front Two Rotor Set (Black) #RB-65012 w/ Brake Pads.
brakeperformance.com - duralast replacements back @ 55k miles warped about 15k miles ago.
@93k - 95k miles (Mid July 2012)
1989 1st Gen Sterling DRW Axle w/Rring Tone & 3.55's Swapped In To Replace SRW Axle w/ Spacers.-
finally! way nicer and gained another 1/2" wide brake shoe per side.
Drivers & Passenger Brake Drums Replaced Motorcraft #BRD15
(made in China! seriously! I payed almost double and still got made in China! not happy!)
Driver & Passenger Wheel cylinders Replaced
Driver & Passenger Self Adjusters Replaced
Passenger Side Brake Cable Replaced
(shoes,and rest of the brakes look really decent.have every new part on hand when needed)
Brake Fluid Flush w/ Synthetic DOT 3-4
Mobil 1 Synthetic Gear Lube LS 75W-140
Passenger Side Rear Axle Oil Bath Seal Replaced #Timken 370047A - seal failure in replacement axle
Carquest Part #2-3050 Rear of Rear Drive Shaft Conversion U-Joint.
(didn't notice old U-joint was too small for older sterling yoke.changed just in time.)
Front of Rear Drive Shaft U-Joint Replaced w/ another Duralast Gold #2-4800DG
Starter Replaced - OEM Gear Reduction Mitsubishi Reman w/ Lifetime Warranty.
Duralast (auto zone) #16561 -
original started dragging.back to split second starts!
Front Tire Rotation -Swapped Sides
Timing Set To 4.5 ATDC - this is when meter failed.i was going for some advance,from 6 to 4.5
to try and get some more economy,but mag pickup reading was off.
I then went by ear,and advanced drastically too high.
Swapped Out Gabriel Ultra's For Bilstein 4600 shocks.
11 quarts of Mobil 1 Fully Synthetic Turbo Diesel Truck 5W-40 Oil & Mobil 1 M1-601
Snapon Mt480 Meter Failed (discontinued mag pickup that was bad,got worse and wasn't
reading rpm's correct,therefore i knew timing wouldn't be any good either.)
Replaced With Ferret Timing Adapter & Digital Timing Light W/ Advance.
Timing Set to 10.5 BTDC. (the max advance of ford specs.shooting for peak economy.)
Curt Manufacturing 51130 Reflex Brake Control
Curt Manufacturing 51312 Brake Control Wiring Harness
Hopkins 40975 7-Way Round / 4-Way Flat Socket and Bracket
Hopkins 40985 Universal Multi-Tow Harness Connector
Transfer Case Flush w/ Mobil 1 Synthetic ATF - Only half a quart! Holds 2.- Keep eye on T-case seal
(probably just forgot to fill with converter swap,and other drive shaft removal events.
it's original as far as I know,so i should just replaced it until it really let's go,if it is seeping.)
New Stanadyne Factory Turbo G Code Injectors.
(I'm impressed! As i figured,BB code over hyped.)
Timing Set to 8.5 BTDC
@95k miles - 98k miles (mid September 2012)
Transfer Case Rear Output Slip Yoke Seal #4503N - keeping my eye on it,i could see it was wet.
explains my fluid loss.
Cooling System Flush w/ Fleetcharge 50/50 mix w/ Distilled Water
New T-stat Motorcraft #RT1049 - started sticking caused my e-fans to run constantly - brand new
replacement
failed too (is why i figured water pump) second replacement working flawless.also learned i can't
trust
cyberdyne gauges thanks to my point and shoot tool and running warm issue.
New Water Pump Motorcraft #PW454
Six New Accuride #29577 Rims To Replace Old Warped Ones
Swapped Out Cyberdyne Digital Gauges For Auto Meter Z Series. - Much more accurate and have
sending units not influenced by ambient temps lol! Won't by them junk gauges again.LED's kept failing
in the things too.
MOOG Drag Link Replaced.- i think it was defective from the start.always heard it "snap" when
cutting the wheels sharp.issue resolved.
Front End Alighnmemt Touch up.
Transfer Case Tailshaft Bushing Replaced.
New HVAC Blower Motor.
Used Dump Body Pump Finally Failed.Replaced with another Monarch.with poly tank this time.#3551k
(bucher hydraulics co. now it looks like.)
Upgraded Rear View Cam Monitor.rearview mirror delete w/ PIPEVISION #VFDD-T701 Overhead Monitor.
Front Mount Intercooler Installed. Overall Size: 31"x12"x3" Core Size: 24"x12'x3" CXRacing #IC0022-BLK
@98K miles - 100k miles (Mid March - May 2013)
HD Upgraded Re-manufactured E40D Transmission W/ Triple Disc Billet Extra Low Stall Converter,
Transgo Tugger Kit,new coolant lines w/ Tru-cool Aux Cooler & bypass/T-stat.
- Reman and Install @98,385 Miles
Transmission Shift Cable Motorcraft #F5TZ-7E395-A
Column Shift Tube dorman #905-100
Ignition Key Lock Cylinder
Instument Cluster Lens bronco graveyard #37124 (ford oem)
Putco Stainless Steel Fender Trim #97211
11 quarts of Amsoil Series 3000 SAE 5W-30 Synthetic Heavy Duty Diesel Oil w/Mobil 1 M1-601
Rear Axle Flush w/Amsoil Synthetic Severe Gear 75W-90
Tie Rod Adjusting Sleeve - Driver Side MOOG #ES2079S (ran over stick of wood while twitching
logs off road
and snapped it.)
Greased Dump Bed
Shortened Rear Tank Filler Neck For Easy Filling of Rear Tank
Replaced Door Striker Bushings & Adjusted Strikers (guess the bushings were ok.replaced anyway.
needed adjustment is all.)
Fresh Coat of Gloss Black Paint On All Sides,Top & Bottom Of Dump Body Along w/ Rear Of Truck Frame.
- Valspar Tractor & Implement Enamel (thinned with naphtha vm&p and sprayed)
Air Filter Wash & oil
100k miles - 104k miles (May 5 - mid July 2013 )
LMC Body Side Molding Installed #49-2663
Stainless Steel Rocker Panels Installed ICI #T0437-304M V panel cut down to half panel
Chrome Hood Protector Installed Stampede #312-8
Replaced Both Rear Stop/Tail/Turn Lamp.Grote #50972
A/C Recharge - didn't hold over the winter.leak someplace.
Autometer Mechanical Water Temp Gauge - looking for even more accuracy so as to run e-fans less.
under hood temps effecting e-gauge readings slightly making it appear as if coolant temps are higher
than they really are.)
Coolant Test - A+ on all levels.Perfect ph and sca levels.Penray filter keeping things nice
automatically.
92-97 Specific Auto Trans Hydroboost Brake Pedal Installed - massive improved driver
comfort/power assist.
2 replacement backup lights - blown.non replaceable bulb style.4" rounds.
Front Valance (lightning style w/ fog light holes) - Replacement #F2TZ17626A
Rotated Front Tiers
Turned IP Up 1.5 More Flats - maxing the oem ip.
Set Engine Timing To 7 BTDC (retarded from 8.5 BTDC)
Penray Need Release Coolant Filter change #NF2088 -July 4th
Replacement Seat.Red Cloth Bench From An '87 Crew Cab - NOS! she doesn't tilt and the color
is off a bit,but
it's new old stock,never used (pulled and sat in barn for years in favor of captain chairs
right off the bat.)
for a Benjamen,i had to grab it,least for a while.1,000 X better than the old gray mismatched
one from my old
9th gen i stuck in there.
104k miles - 106,500 miles (July 15 - Sep 14)
Reman Alternator #DL7765-16-2 Auto Zone/duralast W/ lifetime warranty.
Electric fuel Pump Filter Cleaning.
Oil cooler install.details:
Earl's Performance Temp-A-Cure 16 Row Oil Cooler #41610A
Mocal 200 Degree High-Temp Remote Oil Thermostat #MOC-10ANHT
Perma-Cool Spin-On Oil Filter Adapter #2840
Hy-Lube 1.5-16 Remote Oil Filter Mount
Parker 426-8 ( 1/2" ) High Temperature Hydraulic Hose w/ Jic (AN) Fittings.
Moved Aux Trans Cooler From Behind FMIC To Down Low w/New Oil Cooler Install For More air
flow Through Radiator.
Greatly improved cooling for both oil and water temps!No more high spikes up hill under
load in oil nor water temps.
High Oil temps (up over 260 degrees) were transferring to high water temp spikes under load.
This cured that!
Front End Greased.
Front Brake Caliper Guide Pins Replaced & Greased.All 4.Duralast #H5045
Oil Change Mobil 1 Fully Synthetic Turbo Diesel Truck 5W-40 Oil & Mobil 1 M1-601
Synthetic Fiber Extended Performance Oil Filter @ 106,500 Miles
Electric Fuel Pump Stainless Screen & Bowl Cleaning (lots of water found at bottom)
New Grille Evan-Fischer #EVA17772011239
New Headlight Moldings Evan-Fischer RH #EVA18972011244 & LH #EVA18972011245
106,500 miles - 110,000 miles (Sep 14 2013 - April 7 2014)
Fuel Filter Change - Car Quest #86217
Swapped Out The Dynomax Ultra Flow Welded #17224 For a Larger Walker (BTM) Big Truck
Muffler/Dynomax RV #21470
(wanted to quite things down some more when hauling & towing.it's not stainless like
my ultraflow was,but oh well.
mufflers last long enough i suppose anyway.)
New Solenoid Pack #E9TZ-7G391-A
New Solenoid Pack Connector #36445EAK
New 4R100 Transmission Pan w/ Drain plug #F81Z-7A194-BA
Trans Fluid Change Mercon V w/ Filter
110,000 miles - 116k miles (April 7 2014 - July 19 2014)
Radiator Replacement (seam failure) Ready-Rad Copper/Brass Radiator #432194 *warrantied.
Duralast (auto zone) #16561 *warrantied.honored hassle free.
k&n air cleaner wash & oil
e-pump clear bowl drained and rinsed
Front Brake Caliper Guide Pins Replaced again on drivers side.bent tabs so hopefully
they won't keep sliding out on this side anymore
E-Pump Filter Clean
brake fluid flush
116k miles - 121,500 miles (July 20 2014 - oct 10 2014)
Synthetic Fiber Extended Performance Oil Filter @ 115,500 miles
michelin ltx m/s2 225/75/16 tires x 6 (115,900 miles)
front wheel line up @ 116k miles - bad job at vip
front brake pads duralast DG120
exterior door handles replaced
yellow fog lights relay replaced
aluminum door sills
Walker 21470 Muffler no more vibration!
fixed 4wd shift lever pin vibration!
rearview cam upgrade to Rear View Safety #RVS-771 w/ blue wire snipped to delete grid bars
removed turbo to punch drain holes in the valley to cure oil drips
front wheel line up properly at
tire rotation.X pattern.fronts crossed to inside of rear.two rears brought up.
used bw1356 t-case
rear axle flushed w/ Mobil 1 Synthetic Gear Lube LS 75W-140
used front red crew cab seat updates; fixed back fitting with flip forward rod so now it tilts
and fixed spring to hold slider adjuster
cleaned e-pump screen
121,500 miles - .......127,000 miles (oct 10 2014 - all of this done in oct then truck
sat mostly for winter w/ plowing yards.)
new winter wipers
Penray Need Release Coolant Filter #NF2088 (124,500k miles)
left Front Drivers Side Brake Caliper Replaced (duralast - warranted)
right Front pass Side Brake Caliper Replaced (duralast)
right front pass Side Rubber/Caliper Brake Line Replaced
front brake pads duralast #MKD120
rear brake shoes duralast #583
f450 master cylinder Cardone #13-2689
driver Side Rear Axle Oil Bath Seal Replaced #Timken 370047A - other seal failure in replacement axle
127,000 miles - 135,000 .....(april 6 2015 - aug 21 2015
Synthetic Fiber Extended Performance Oil Filter @ 127,000 miles
timing advanced to 8 BTDC? check - whatever it is,is great.15 mpg again!
Front wheel line up
Frame repair on both sides above the wheels
Earl's 42500AERL Temp-A-Cure Oil Cooler.old one sprung a leak from bumping it with plow years back.
Dee Zee Running Boards DZ2017
front end greased
used E4OD shift cable bracket
new e4OD shift cable F5TZ-7E395-A
new range sensor - MLPS - neutral safety switch - Motorcraft SW5978
new idler pulley
new belt Duralast Belt #1080K6
135,000 miles - 142,500 miles aug 21 2015 - dec 2015
front end greased
air filter wash and oil
new fuel filter racor f829b
new Motorcraft CX1448 Throttle Position Sensor
new bull moose ip injection pump
hypermax smoke puff limiter
timing set to 8 BTDC
water pump reman from carquest
rear of rear driveshaft u-joint was an emergency fix.i think it was moog 448.for sure
bought @ car quest.
front of rear driveshaft u-joint moog #354 @ car quest.
most current list,still in the works:
set of 6 firestone transforce a/t tires 225/75/16
front and rear of front driveshaft u-joints both replaced.moog 265 - autozone lifetime
warranty
12 quarts of Mobil 1 Fully Synthetic Turbo Diesel Truck 5W-40 Oil w/ Mobil 1 M1-601
Synthetic Fiber
radiator support from Texas installed w/ mount kit from bronco graveyard.
power steering pump seal kit.res and lines o-rings replaced from it.
new flexplate ATP Automotive Z-344 Automatic Transmission Flywheel Flex-Plate from amazon - due to rounded off teeth.
reman starter from auto zone installed.replaced under lifetime warranty.
CURT 48007 Receiver Mount Combination Ball and Pintle Hook - too low but will have if in need of pintle.
CXRacing OC-248-30-AN10 found on ebay under RW-OC-248-30-AN10
rear tank fuel sending unit part# F2TZ9275D NOS on ebay.
timing set to 9BTDC
chip box redone.
and yes.yes i do have one just like it for log truck lol.you guys didn't think i drove around in a little honda civic when i don't need a truck,because that's what i prefer did ya? it's cus these rigs ain't cheap.
