1983idi
So I've been flushing my cooling system for a while now. Probably gone thru 80 gallons of water. First I flushed with tap water and then I flushed with distilled water. Every time I flush it I pour until it comes out clear but them when I run it for a few days it turns to a rusty orange color. Do I just need to put the coolant in and call it good? Is the 100% water mixture rusting the block and causing that?
My biggest concern is that I got the Fleetcharge Coolant which comes with SCA's and was told that I need to make sure I have everything flushed out before I add it so the new coolant doesn't react with the old coolant. If there is orange crap am I not getting all the old coolant out?
Also block plugs are stripped out so the lowest points I can drain from are the 9/16 plug thats on the coolant tube elbow above the oil filter and the lower radiator hose and radiator drain ****
Thanks in advance for any help
