IH POWER
ALL MOTOR!
That area is a tuff place to seal because there are several corners that require plenty of rtv. Now the big question... Did you install a cork or rubber oil pan gasket.... If so you will never stop the oil leak. These engines never did have an oil pan gasket. What the factory did was use rtv and its worked very well for many years. Just because the oil pan gasket is offered in the aftermarket does not mean we should use one. They just never seal properly. Now its time to pull the engine and clean off the gasket. I found that permatex ultra copper plus works great. I never have had a leak useing thats for sure... Removeing the front cover will get you past for a while but that pan gasket needs to be removed...
Neither. Never had the pan or cover off.
