timothyr1014
has anyone swapped there rear tank to the larger bronco tank? If so what all is involved...I would seriously love adding another 30% to my range, and giving up the spare is not an issue
I used a tank from a 96 bronco I was parting out anyway. the tank in the bronco mounts in the frame rails, I used the cross sections as spacers as the tank is way deeper than stock. drill out the top of the rails to match the stock bolt locations and its a direct bolt in from there. the level sender off the bronco unit fits on the diesel pickup to run the fuel gauge.
great mod imho.
punk
you would need a 2-3" body lift (maybe more) and then it may work. In theory anyway.
punk
great mod imho.
punk
can you elaborate on the cross sections and how you used them as spacers please? i just picked up a complete bronco tank with sending unit out of a 96 for $30.
