Blown head gasket
david85
Campbell River, B.C.
As others have said, look at the oil cooler. I'm not saying you shouldn't refresh the head gaskets and install studs while you're at it. But a head gasket failure symptom is an overflowing coolant recovery tank, Mixing fluids is not as common. At this point, I don't advise letting it run long enough to see this happen, but no matter what you do, I'd install a seal kit in the oil cooler.
My oil cooler seals recently let go and pushed oil into the coolant. @typ4 can set you up with a kit.
