Big round disc on back of transmission
nyteshades
Tulsa, OK/Ashland, WI
Long story short, I bought another 89 f350 for the motor and zf transmission. This one is a 2 wheel drive. There's a big disc on the back of the transmission that the driveshaft goes into. Am I right in thinking this is the parking brake and the "regular" 2 wheel drive transmission just had a yoke on the tail shaft? In other words, the big round disc should unbolt and I can bolt my transfer case up to it? Right?
gonecrazyi
florida
Sounds like a superduty tranny. If it is its actually a 4x4 tranny with an ebrake bolted to the back instead of a tcase.
rjjp
Needs to go test
Clare, Mi
The tranny mounted parking brake looks like a drum brake on the back of the tranny.
jukess289
powhatan va
the zf 5 speed are different for 4x4 and 2x4 i dont thank you can unbolt the parking brake and put on transfercase but maby
the trans that can take a transfer case and the parking brake at the same time is indeed the 4wd trans. the genuine ZF5 for the superduty(88-97) has a deeper first gear.
nyteshades
Pics..
Am I right? Is this trans going to accept a tcase?
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
If you unbolt that disc and there are 6 bolts for it plus an alignment pin, then I would say yes, it's a 4X4 tranny.
HankHill
NY
im not positive but that does look like a old superduty tranny
