big hp idi
idibeast
Granbury,TX
In response to some of you guys, my deffinition of high hp is 500+, not exactly daily driver but i dont think 150cc of fuel is gonna get you there.
Devon Harley
San Diego
You can run in-line an step away from db/pumps someone is gonna use around 300cc in a Idi drag truck soon I hear.
88 Ford
San Diego, CA
I figured I would save you guys some reading. These are the idi head flew numbers directly from RacinNdrummin:
All measured at 28" of water column
Intake
.100" - 69cfm
.200" - 128cfm
.300" - 175cfm
.400" - 184cfm
.500" - 187cfm
Exhaust
.100" - 45cfm
.200" - 82cfm
.300" - 119cfm
.400" - 147cfm
.500" - 163cfm
88 Ford
San Diego, CA
Here is some more of the info posted by Justin:
Here is stock 6.0 head flow specs... And thats a 4 valve head..
Intake port...
.000 Lift 0 CFM
.050 Lift 41.4 CFM
.100 Lift 80.4 CFM
.150 Lift 119.9 CFM
.200 Lift 145.4 CFM
.250 Lift 152.0 CFM
.300 Lift 154.8 CFM
.350 Lift 157.4 CFM
.400 Lift 159.3 CFM
.450 Lift 161.0 CFM
.500 Lift 161.9 CFM
.550 Lift 163.0 CFM
.600 Lift ----------
Exhaust Port....
.000 Lift 0 CFM
.050 Lift 37.0 CFM
.100 Lift 69.9 CFM
.150 Lift 93.2 CFM
.200 Lift 106.1 CFM
.250 Lift 111.2 CFM
.300 Lift 116.8 CFM
.350 Lift 119.2 CFM
. 400 Lift 159.3 CFM
.450 Lift 161.0 CFM
.500 Lift 161.9 CFM
.550 Lift 163.0 CFM
Exhaust Port....
.000 Lift 0 CFM
.050 Lift 37.0 CFM
.100 Lift 69.9 CFM
.150 Lift 93.2 CFM
.200 Lift 106.1 CFM
.250 Lift 111.2 CFM
.300 Lift 116.8 CFM
.350 Lift 119.2 CFM
.400 Lift 120.7 CFM
.450 Lift 121.3 CFM
.500 Lift 121.9 CFM
.550 Lift 122.3 CFM
.600 Lift 122.7 CFM
Tested at 28"*
Stock head flow numbers - PowerStrokeNation : Ford Powerstroke Diesel Forum
Needless to say, I think 200+ CFM out of the intake is going to be a cakewalk...
The exhaust side is great after the valve is open halfway, but low lift flow is abysmal... And the funny part about it, is the stock cam doesnt even open the valve far enough to take advantage of the sweet spot in exhaust flow...
I am going to take one of my spare heads, and do some porting/valve angle testing... I will report on this thread when I find what I find...
The key to these heads is exploiting low lift flow, and a lot of that is accomplished by a good valve job
racer30
western Oregon
Hey IDIBeast, You need to say HP at the crank or at the road. The drive train loss in the truck can varry from 25% to 30% based on the wieght of the tire wheel combo, NBM2 had his drive train loss as per the dyno at 29% that put him at 466 crank HP on 136cc's of fuel. I was at the dyno when he pulled his runs and Got to ride in his Truck. To say it was impressive is a understatement. He spent alot of money on things that add power, the custom pipes and turbo mount was nicely done and the new cam made it posible to make the engine use the intercooled air better. The cryo treating dosent add power all the powder coating and paint too, but looks cool under the hood. I think 300 crank HP is possible with 90cc's of fuel, and the J2 cam and a good turbo. I hope to do just that with my build. 240 Wheel HP is 300 Crank HP at 25% loss and dirtydiesel did that with his build and a turnd up Turbo pump, several other trucks have put down about that with similar builds. Getting over 300 to the wheels will need a bigger pump like the DB4 Hybrid pump that will do 120cc up to 180cc and thats where the money is spent. Throwing 5000.00 at the engine would be nice, But IMO Its not a must. I will have about 2500.00 in my build and 500.00 of that was for parts to make it mate to my Allison trany in my Motor Home. I have traded and sold parts from 5 engines to get to this point so that helps alot. Its all about what you realy want under your hood. I hope to build myself a F250 IDI after I move to AZ in a year or so, I will go a bit more aggressive on that engine, Its nice to be able to build it slow with lots of time for trading and stuff, I would hate to have to build one in a hurry, it will triple the cost. Just my 2 cents on HP.
Wicked97
Nebraska
Because our heads outflow the 6.0 heads. And Al asked for documentation of such.
As they should. 2v heads for a 444 cid motor and a set of 4v heads for a 365 cid motor. That's like comparing a 351 a 429 and being surprised. There is no comparison.
88 Ford
San Diego, CA
A four valve head has to extra valves and the heads aren't on the block when they are tested, so cubic inches has no bearing on the test...
88 Ford
San Diego, CA
Racin's numbers were a bit skewed cus his clutch was slipping and didn't load his clutch but if you take the dyno results from his dyno with the turbo cal IP and the numbers from NMB2's dyno, the horsepower per CC of fuel equals between 2.6-2.7. If you take the 180cc of fuel that Racin is at and multiply by 2.6cc/hp that equals 468hp. If you add nitrous to that, 500hp isn't out of the realm of possibility...
Wicked97
Nebraska
umm no not even close. First off flow bench's have cylinders that simulate bore size otherwise the results are not usable. Second the 6.0 head was designed for a motor with a 365 cubic inches that means the ports and valve size were optimized for a small cubic inch motor that doesn't need much air. Just because it has 4 valves doesn't make it comparable. Cubic inches of each motor has every thing to do with this.
Thanks for those numbers I"ll be copy paste those ASAP to a file, have a guy look that stuff over and see if I can do something with that info.
And head to head with no regard to engine displacement, our heads do not too bad I would have thought that the 4v head should have done way better as they do make more power stock!
This says a tremendous amount to what can be eeked out of our engines with the correct combination of parts....up to the point of KaBoOm when all the magic smoke comes out and everything goes awry in a flash! That is the point a magic Genie needs to come round and grant ya 3 wishes!
Devon Harley
San Diego
Jared just shh you don't know what your talkin about lol jk man thanks for posting that for me.
88 Ford
San Diego, CA
Granted I was being general and I know that valve size does have an affect on flow as well as being tuned to the engine but from what I read from those head numbers from the idi seem pretty good.
mitsu tractor
