EvergreenRanch
In Transition
ok boys i think i caught this fairly early on so im hoping there isnt too much damage if any. Engine prolly only ran for a couple hours in this condition. This is just an educated guess, but i think only thing wrong is a stuck thermostat. pulled it last night and it looked pretty much done for. i had two options as far as what themostat to put back in. i made a few phone calls and no one had either of the thermostats that i have seen posted here on the board. so i made more calls. Standt (sp?) makes one that is factory spec. and i found one. its a 195* operating temp and it looked extremly well made and engineered. all measurable dimensions were compared against the one i removed with a micrometer and its identical.
Ok next issue however. if the issue is not the tstat, what should i do? little bit more background: way i figured it out was there was high temp at top of radiator after a short distance, so out of habit i checked the lower return hose and it was cold. major red flag. Could this be a blocked radiator? if so whats my course of action? there was plenty of coolant behind the tstat when i pulled it which is why im wondering if it could be a block in the radiator.
what should i and can i check to see if damage has been done? i know you can fry pistons and rings with too much heat, but is there anything specific about our engines that i should change, replace, do anything to after this.
What is the Worst Case Scenario?
Also: is anyone near Contra Costa County California? East San Francisco Bay Area?
