best transmission?
Diesel_brad
Dunce
gilbert pa
well when he got the truck it had 35 inch superswampers on it and it was 4x4, ik the back axle is huge, if it matters i did have to put an adapter on the axle for it to be srw
Here is a simple question to answer to answer. Does your rear axle have disc brakes?
hesutton
The Anti-Anderson
Bowling Green, KY
I am curious just as the axle is about 2" narrower and the spring pads are 5" narrower. And then you are stuck w 10 lug dually wheels and they dont fit on a pickup frame
Yup, it's not just a bolt on for sure. Will need mods to work, plus, I'm seriously thinking about machining/modifiying the hubs to the standard 8x6.5 and ditch the 10x7.5 pattern. It's been done before........see below:
STOCK DODGE DANA 80 ON LEFT, MACHINED 10 LUG CENTER, STOCK 10 LUG RIGHT
Good point, I didn't think about that yesterday.
Heath
