Best order to install factory turbo parts?
DrCharles
West Plains, MO
Thank you! It's nowhere near the wye, which is good to know. The Autometer pyro probe sticks out about 1.5" and makes a right-angle bend before the wires come out of the sleeve, so it can't be too close to anything.
It looks like a location near the cast-in numbers (Pat. Pend. on yours) would get flow from both sides of the engine. Will also check to make sure it clears the frame rail before I drill a hole in an expensive casting.
Thewespaul
Bulverde, Texas
Make sure you have enough room to actually remove the pyro, it sits pretty far into the pipe
DrCharles
West Plains, MO
BTW the hose I ordered from McMaster (link a couple posts ago) is not ideal. It won't work without an elbow since it's soft enough that any bends just collapse. I think it'll work with a 1" barb elbow in the middle between the CDR and the airbox nipple.
Meanwhile, still looking for the "right" hose to make it from.
Thewespaul
Bulverde, Texas
Here’s the part number off an old banks adapter hose. Maybe it will help ya
ttman4
Last Nite's Dream..
Wes, in the pic you posted in post #30, where you mt the pyro?
In my '90 CC Dually (intercooler not hooked up yet) I currently have mine in upper part of my re-modified Banks dn pipe with my factory turbo. I've never hard worked this '94 IDIT engine since I stuck it all in. Need to get used to it & where/what to safely pull the EGT to when I'm pulling some of my really big nasty loads I occasionally pull.
Reason I ask, when I was running my ATS 088 kit the pyro was in the inlet snailshell & I'd pull up to 1200* -some 1250* but then back out back dn to 1200* & all was good & I was used to it. Now with this factory 093 & Typ4 rebuild I got to find out what EGT will be safe when I pull/work it hard. I've had some tell me around 900* now.
And Dr Charles, if you mt your pyro in the wye casting I wonder what a safe EGT would be safe mted there?
I've seen a couple these engines "melted" & it ain't purrdy. LOL
DrCharles
West Plains, MO
I figure that in the wye casting is only a few inches further from the exhaust port, and due to its thickness the gas probably won't be significantly cooler than in the manifold. I'm not going over 10 psi boost since I don't have head studs and expect this engine with (allegedly) 188K miles to last the rest of my life. So 1100 on the pyro is high enough.
The reason not to put it in the downpipe (despite Banks supplying a bung) is that the temp drop through the turbine is proportional to the amount of energy being extracted from the gases to make boost. So you really have no idea what the pre-turbo temp is. 900 post-turbo is probably safe. But maybe not.
Banks has a good article: https://www.bankspower.com/tech_article/why-egt-is-important/
Thewespaul
Bulverde, Texas
I put mine in the top of passenger side crossover pipe in a weld in bung, that’s pretty much the same distance from the port as where Charles will have his, I run up to 1200* in that location with no issues at all. Personally I think these engines could handle higher egts than 1200, but it puts a lot of extra wear on components.
DrCharles
West Plains, MO
Another question. The CDR mounts to the bracket on the valve cover. But there's supposed to be another mounting plate, a separate piece, which I don't have. It's #25 on the attached pic from Typ4.
What does that plate do - secure the rubber grommet that slips over the snout of the CDR? Do I have to make one, or can I just clamp the grommet in place? The diagram already shows a hose clamp there.
  • 93-94 IDIT TURBO SEAL-GASKET-REFERENCE-GUIDE R01.pdf
Thewespaul
Bulverde, Texas
The file won’t open for me, the factory turbo setups use a grommet sandwiched between the cdr and the hose adapter, you should be able to make one pretty easily with some flat stock and a barb fitting and a little welding
DrCharles
West Plains, MO
I think because it's a .pdf it just downloads a copy, then you can open it locally. That's what it does on my laptop, anyway...
Sure, it doesn't look hard to make one, but if I don't need it, why go to the trouble ;) Thanks for the pic. That plate looks like it does nothing except keep the grommet from coming off the end of the CDR tube. I have the grommet on order, will see when I get it all together with the 1" ID hose and a clamp. It's actually not just a ring...
https://www.ebay.com/itm/Ford-6-9-7...-Breather-PCV-Valve-Retainer-OEM/201453808961
Thewespaul
Bulverde, Texas
It is just a ring, the link you posted is the adapter for an na truck that goes between the valley and the cdr mounted on the intake manifold
DrCharles
West Plains, MO
oh well, guess I'm out $10 then ;) Is the snout of the CDR the same 1" diameter as the nipple on the airbox? I must be missing something since I don't see why that piece (and grommet) would be needed at all... :dunno
Thewespaul
Bulverde, Texas
There’s only a nipple on one side of the cdr, and that’s what goes into the valve cover (or valley pan on na engines) the adapter is so there’s something for the hose to clamp onto.
