plywood
Recovered N/A
Not yet but I thought I'd put the idea out there and see if someone gets it together before I do.
While reading about I think it was Ocnorb and his water/air setup and his report of a heat soak under extreme conditions I wondered if the electric water pump wasn't pumping fast enough liquid to shed the heat.
Sooooo,,,, while at the junkyard the other day I noticed an old Audi with a belt driven water pump with probably 5/8 to 3/4 inch lines. Grab one of those, mount it up, maybe grab the radiator too with the electric fan and shroud, and all you need to buy new is the Intercooler and some hose and you have a low lag top mount intercooler with little piping that isn't in front of the engine (other than the fairly small radiator) and plenty of charge air cooling power.
Can not find it now buy somewhere yesterday I saw a youtube video of a setup with intake temp gauges before and after the Intercooler. You can hear the truck accelerate, and the turbo spools up and the charge temp goes over 300 degrees, the post Intercooler temp always stays with a couple degrees of 102 or so, which must have been the ambient temp at the time.
