Automatic Trany Flex plate
ldebrois
91 D250 Auto 4x4
Laramie,WY
New member a few questions Flex plates
I was wondering if any of you had an idea on what would cause my flex plate to keep sheering. I replaced it just a year ago when it sheered and it has done it again. Maybe by getting a thicker than stock plate that it might hold up better but i'm not too familiar with these auto transmissions. if you have any ideas or fixes that would be great. Thanks Lee
ni_radar
Armow/Ontario/Canada
the dodge diesel's are known to break those plates, there is heavy duty one's available aftermarket. you could check and make sure the dowels are there. If your truck is producing a lot of horsepower you will break the stock plates a lot.
ldebrois
91 D250 Auto 4x4
Laramie,WY
Ok, I ended up buying a aftermarket flexplate that is thicker but i havent been able to put it on yet. I will check if the dowels are there and thanks for the reply.
