DeepRoots
Tug Engineer
thats the collector pipe not the downpipe.
the downpipe is on the floor next to the crossover.
I ended up making my oil line out of 5/16" steel line and wielding on a fitting on the turbo end with a double flair fitting on the engine side. I was kinda stuck with mine and didn't have an easy source for an oil line. I do not recommend trying to make a line like I did because mine kept cracking. Its holding now after my dad showed me how to prevent the embrittlement that was happening.
The T4 center section on the T04B turbocharger that this kit uses is VERY common and any turbo or performance supplier should be able to get you what you need.
You get the filter from a normal parts store?
Okay here's a question, where did you hook up the boost gauge to?
Any pics of it?
