WrickM
Let's have a compromise for the turbo only guys, so we can all hang together.
And I don't think it has been done on an IDI yet, but could be wrong.
Small Roots or screw compressor for that fat bottom end torque,
Remote mount turbo compounding the supercharger for the top end..............
Now to find a way to weld the heads to the block so they don't blow off!
I worked for a company that did that very idea. . . well not remote mounting. but the super and turbo charging. It was a test to see if we could make a cheaper turbo kit for the already supercharged GM 3.8v6. It workd, in fact it put in some really fast times (low 10's i believe) but it just was overly complicated when working around the eaton m90 supercharger air bypass valve.
For all those talking about how turbos are better. . Well sure they are. They are simply fantastic for diesels to the point that even some of ther limitations on gas engines are overcome. Still, haven't you wanted to do anything different?
you could run a medium size blower like a Eaton M112 on an elongated intake manifold. It doesn't HAVE to be on the block, especially because you don't need to plum the bypass valve. delete your AC and run a supercharger pully in it's place. The low end would be out of this world.
