johnnyb1
I have a 87 with a C6. Did they put a AOD with a idi? Or would I have to go to a ZF5 to get the overdrive? That sounds like alot of work and expence.
I've had an AOD and a E4 and, like you said, both in 150s. Don't remember ever seeing a od until the 'stroke. Had a ZF5 and it would not die. Maybe aux. od would be cheaper than a swap. I need to look at that option.
