Kevin 007
Full-floater
Today I removed the factory 1G alternator from my 84. Installed a new 3G that I bought from DB Electric, for about $90 I think. Ran the yellow wire from the 3G harness to the battery post, green wire to the green external regulator wire (F terminal on the regulator), and the white wire to the adjacent plug, 4 gauge wire to a 175 mega fuse and then to the battery (which is a group 31). Fired it up with 14.4 volts at idle right away and down to 13.5 under full load of, aux. high beams, fan on HI, aux. back up lights on, stereo on and wipers full blast. Im happy with that. Put a V-belt pulley on it without having to shave any material off of the alternator casing. Put regular strength Locktite on the treads and used the lock washer that came with it. Hopefully it stays on. Have many of you had them back off and pulley fall off?
So now I will add that to the list of significant and practical mods done to this lucky old truck
